more io pins than in a device
Hi, i am using quartus prime pro and compiling the one of the intel's ip.It is showing more io pins than in the device.but i want to compile it to see the resource utilization. In the final design this is not the top level module.please help me how to do full compilation without worrying of io pins.in vivado we have synthesis settings to overcome this problem.
Thanks in advance...!
What IP? Where are you seeing an issue? More details needed.
You can use virtual pin assignments in the Assignment Editor to temporarily place I/O before assigning them to a physical pin.
- sstrell
