mahender's avatar
mahender
5 years ago
more io pins than in a device
Hi, i am using quartus prime pro and compiling the one of the intel's ip.It is showing more io pins than in the device.but i want to compile it to see the resource utilization. In the final design th...
  • sstrell's avatar
    5 years ago
    What IP? Where are you seeing an issue? More details needed.
    You can use virtual pin assignments in the Assignment Editor to temporarily place I/O before assigning them to a physical pin.
