10 years agoModular SGDMA Streaming
Hi, I'm trying to stream data from an ADC to my DDR RAM. I’ve hit a roadblock with using the modular SGDMA core to do streaming to memory mapped transfers to DDR RAM. An interrupt that is suppo...
10 years agoYour image is so small it's difficult to see. Can you add a signaltap instance on the stream interface to check that anything is actually going through it?
As for your problem with the macros, it's probably because the 32DIRECT versions use a byte offset, while IORD/IOWR use a word offset. Therefore you either need to multiply testNumber by sizeof(int) in your line with IOWR_32DIRECT, or only use IOWR and IORD. This should probably work:IOWR(MEM_IF_DDR2_EMIF_0_BASE, testNumber, testNumber);
IORD (MEM_IF_DDR2_EMIF_0_BASE, testNumber); Using direct addressing, either with pointers or memcpy work also, but you need to be careful if your CPU has a data cache. Then you need to flush or invalidate it before or after the operation.
