14 years agoModelsim/TCL problem
Hi!
I'm writing a TCL script to automate simulations in modelsim. When I left work last night, my script worked fine. This morning it causes modelsim to freeze, and I've identified the script that causes it but I can't figure out why. do "run_$file_name.do" onbreak resume for {set x $holder} {$x >=0} {incr x -1} { run -all } What I'm trying to do, is loop through the number of tests I want to do, and then return control to the script when they are done. This is one of the SEVERAL methods I have tried to use to return control to the script. All of them involved looping of some sort. Modelsim runs all the simulations just fine, but when it tries to return control to the script, it just freezes. I used a while loop before, using signals from the simulation to trigger the loop to stop, but that doesn't work anymore either. Any insight would be greatly appreciated! Thank you in advance!
