8 years ago[ModelSim] Where to see a log of the commands
Hi All,
Where can I see a log of all the commands, which ran in ModelSim ever by manual entering/typing in the Transcript window or by using ModelSim buttons? Thank you!5 Replies
--- Quote Start --- Hi All, Where can I see a log of all the commands, which ran in ModelSim ever by manual entering/typing in the Transcript window or by using ModelSim bottoms? Thank you! --- Quote End --- Apologies dmitryl but I didn't know Modelsim has bottoms? - Altera_Forum
I meant "buttons" :-) So, do you have an answer? Where is a log file of ModelSim/Questa located? What's the log name?
--- Quote Start --- I meant "buttons" :-) So, do you have an answer? Where is a log file of ModelSim/Questa located? What's the log name? --- Quote End --- yes the filename is "transcript" and should be either in modelsim directory or as decided by modelsim.ini for example you may have the following ini command: ; File for saving command transcript TranscriptFile = transcript - Altera_Forum
How can I change a location of the Transcript File?
Currently it's located and updated here: "C:\questasim64_10.4c\examples\transcript" But, the project itself is located here: "D:/units/hp/led/msim/project" So how to set so all the Modelsim files will be located/updated in the project directory? - Altera_Forum
Is there any response? Should the transcript file be in the project directory? How to change its location?
