8 years ago[ModelSim] Where to see a log of the commands
Hi All, Where can I see a log of all the commands, which ran in ModelSim ever by manual entering/typing in the Transcript window or by using ModelSim buttons? Thank you!
8 years ago --- Quote Start --- I meant "buttons" :-) So, do you have an answer? Where is a log file of ModelSim/Questa located? What's the log name? --- Quote End --- yes the filename is "transcript" and should be either in modelsim directory or as decided by modelsim.ini for example you may have the following ini command: ; File for saving command transcript TranscriptFile = transcript
