14 years agoModelSim "out of range" issue
I have the following code:
Library IEEE;
use IEEE.Std_Logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.Math_real.all ;
WIDTH_DQ : natural := 9 ;
X : in integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ;
Y : in integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ;
signal lxn : integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ;
lxn <= X - Y / (2 ** RANK) ;
During RTL simulation at RANK = 2 in time X = 226 and Y = -113. I'd expect lxn to become 254 and well within range. But ModelSim tells: --- Quote Start --- # ** Fatal: (vsim-3421) Value 261 for lxn is out of range -256 to 255. # Time: 88 ns Iteration: 3 Process: /tp_cordic_vhd_tst/i1/genel(3)/regel/genpure/line__252 File: C:/qdesigns/bv5fpga/c-cam/bb/arithmetic/TP_cordic/cordicelement/cordicelement.vhd # Fatal error in Process line__252 at C:/qdesigns/bv5fpga/c-cam/bb/arithmetic/TP_cordic/cordicelement/cordicelement.vhd line 294 --- Quote End --- It looks like ModelSim is taken the representation of -113 as 'unsigned' and added 1/4 of that giving a result of 261. Any clues?
