16 years ago
ModelSim: no ouput for assert statement
Hallo,
I started to experiment with VHDL simulation and verification lately, so I wrote a testbench and simulated it with ModelSim-Altera 6.e1 Starter Edition. The testbench includes some assert statments but unfortunatly Modelsim doesn't display any errors when this assert statements are executed. I enabled "Enable assertion debug" in the Simulation Properties window and checked the settings in the Runtime Options window.
Can anybody tell me how i get Modelsim to display an error-message when an assert statement is executed?
The testbench can be downloaded here (http://www.stefanvhdl.com/vhdl/vhdl/tb1.vhd) (it's from an online course (http://%3cbr%20/%3e%0ahttp://www.stefanvhdl.com/vhdl/html/basic_stim_gen.html))
Thanks in advance,
magixD
    The report part of an assert only occurs if the statement is false. The way I remember it is:
    assert (all is good) report "all is not good" severity failure;
    I know, I wrote the assert statement so that 'all is not good' ;)
    This is the source code again (it's the same as in the link from the first post):
    library ieee;
    use ieee.std_logic_1164.all;
    use std.textio.all;
    use ieee.std_logic_arith.all;
    use work.txt_util.all;
    entity TB1 is
    end TB1;
    architecture test of TB1 is
        signal x1:    std_logic;
        signal x2:    std_logic;
        signal y:     std_logic;
    begin
    test_seq: process
        variable cnt: integer := 0;
        --*variable slv: std_logic_vector(X2'range);
    begin
        x1 <= '0';
        x2 <= '0';
        wait for 10 ns;
        x1 <= '1';
        x2 <= '0';
        wait for 10 ns;
        x1 <= '0';
        x2 <= '1';
        wait for 10 ns;
        x1 <= '1';
        x2 <= '1';
        wait for 10 ns;
        assert y = (x1 xor x2)
          report "E@TB: circuit failed"
          severity Error;
            report "E@TB: failure at: x1="& std_logic'image(x1)&
                    " x2="& std_logic'image(x2)
            severity Error;
            report "E@TB: failure at: x1="& str(x1)& " x2="& str(x2)
            severity Error;
        x1 <= 'X';
        x2 <= 'X';
        wait for 30 ns;
        x1 <= '1', '0' after 10 ns, '1' after 20 ns, '0' after 30 ns;
        x2 <= '1', '0' after 20 ns;
        wait; -- stop process
    end process test_seq;
        -- this is supposed to be an xor ... but it isn't
        y <= (x1 and not x2) or (x2 and not x1) or (x1 and x2);
    end test;
