ArthurDent
5 years agoModelSim INTEL FPGA STARTER EDITION supports only one user on linux
Hi
We are using Quartus Prime Lite 20.1 .1 which includes Model Technology ModelSim - INTEL FPGA STARTER EDITION vsim 2020.1 . The tools are installed on a linux (CentOS 7) server which is the mai...
- 5 years ago
You can use ModelSim - Intel FPGA Edition alone to perform simultaneous simulation with different users as you intended.
If you install on two different machines I don't think you'd be able to perform simultaneous simulation with different users. It doesn't hurt to try though.
Do you have any further questions?
Nurina
Nurina
5 years agoHi,
Can you give me the following information:
- Do you have other ModelSim instances installed in the server?
- ModelSim Starter Edition has a line limit of 10k lines, are your designs possibly exceeding that amount?
- Are you able to launch ModelSim successfully at all times?
- Does this happen no matter who the first user is?
Nurina
- ArthurDent5 years ago
Hi Nurina
- We have also "ModelSim ALTERA STARTER EDITION vsim 10.5b " installed, but it is not used.
- The design simulates fine when no other users use vsim so it doesn't seem to be a line number issue.
- The first users have no problems launching and running simulation.
- Yes, it is not connected to a specific user.
If the first user only starts the ModelSim GUI and are not running a simulation, then the second user can use ModelsIm without any issues. If the first user has an active simulation, then the second user is kicked out after 5 min with "** Fatal: vsimk is exiting with code 4."
BR
AD
