16 years agoI don't use any tristate in the design. I found out that the Z is caused by unused bits in internal signals(vector). I have no idea why does modelsim display unused bits in high Z condition.
eg. reg [3:0] a ; reg [3:0] b; reg [7:0] result; output reg [3:0] result_truncate; result <= a * b; result_truncate <= result[7:4]; the signal result[3:0] will be high Z. How to set the modelsim to display the Z value as zero value? --- Quote Start --- Unitialized signals would show as 'U', driver conflicts as 'X'. --- Quote End --- from my past experience in using the modelsim, whenever deal with X, it always relate to uninitialized of signal if the X happen in the beginning of the simulation. It uses X instead of U. Besides, X also represents driver conflict when in the middle of simulation.
