--- Quote Start --- I am trying to simulate RTL using the Altera Multiply component instantiated in a state machine using modelsim. This is not the inferred multiplier but the lpm component sized to 32 bits. The problem is the component does not respond/work using the functional simulation mode. The RTL functions correctly in the Cyclone chip where I developed it but now as I am trying to develop a testbench for others, I can't get it to simulate. Can I do a functional simulation in RTL that I have instantiated a component? Thank you, Don --- Quote End --- For those interested, it certainly appears that this is the case. If I compile in Quartus for a timing simulation and use the .vho file with my test bench, I get results! Thanks, Don:) - Altera_Forum
Im guessing some bugs in your code. THe LPM components have been around a very long time and will match real hardware behaviour.
How about posting your code here?
