16 years agoThanks sanmao,
I just rewrote these three attached modules which shows the behaviour. one module should write to the other which will then produce final data. If I connect final data out of toplevel then data is ok. If I keep it internal all is dead. However, the internal connection across the two modules fails to drive. Regards
