ModelSim Error
Following another community response, I tried this:
"It's a bug. In the Simulation Waveform Editor, choose Simulation Settings|Simulation Options and delete -novopt following vsim in the Model Script (and save the changes)."
Now I am getting another error:
This is the code for my 2x1 multiplexer:
module mux21(out, A, B, Sel);
input Sel, A, B;
output out;
assign out = Sel?A:B;
endmodule
Any suggestion?
I tried the above verilog code one more time without changing anything else. Now I am getting a different error. I desperately need some help?
- MR233 years ago
Mr. Moderator,
I am having the exact same error. Please find below the code I used this time. One thing, I want to mention here is that I have been using Quartus Prime Standard edition for last 4/5 years ( Got the license from Altera as a donation). I used only the verilog code to generate the VWF form without any issue until recently. It's really frustrating......
// define a module for the design
module mux21(in1, in2, select, out);// define input port
input in1, in2, select;// define the output port
output out;// assign one of the inputs to the output based upon select line input
assign out = select ? in2 : in1;
endmodule
module test;
reg in1, in2, select;
wire out;// design under test
mux21 mux(.in1(in1), .in2(in2),
.select(select), .out(out));// list the input to the design
initial begin in1=1'b0;in2=1'b0;select=1'b0;
#2 in1=1'b1;
#2 select=1'b1;
#2 in2=1'b1;
#2 $stop();
end// monitor the output whenever any of the input changes
initial begin $monitor("time: =%0b","input1 =%0b","input2 =%0b","select =%0b", "output =%0b", $time, in1,in2,select,out);
end
endmodule
