13 years ago
ModelSim Error: (vsim-3009) [TSCALE]
I downloaded and installed the ModelSim tools (Altera Starter Edition 10.0d) from the Altera website. Attempting to get thru the tutorial (Under Help in ModelSim), I get this error when I try to load test_counter (as directed on page 16 of the tutorial):
ModelSim> vsim work.test_counter# vsim work.test_counter # Loading work.test_counter# Loading work.counter# ** Error: (vsim-3009) [TSCALE] - Module 'test_counter' does not have a timeunit/timeprecision specification in effect, but other modules do.# Region: /test_counter/dut# Error loading design
Can someone please help me resolve this? Thanks. It's difficult when the tutorials don't work.
Doug
    Add this to the top of the file that Modelsim is complaining about:
    // Modelsim-ASE requires a timescale directive
    `timescale 1 ns / 1 ns
    Cheers,
    Dave
    --- Quote Start ---
    --- Quote End ---
    Thanks, Dave. I appreciate it.
    Doug
    You can always try typing
    verror 3009
    to see if there is more information about the error you are getting. In this case, it produces
    $ verror 3009
    vsim Message# 3009:
    A module without a `timescale directive in effect, and without
    explicit timeunit and timeprecision declarations, uses the
    simulator resolution limit for both its time unit and time
    precision. This may result in incorrect delays and unintentional
    behavior in the module. Beware of simulator performance impact,
    and consider using the vlog -timescale or vopt -timescale options
    as a workaround. This message can be downgraded to a warning with
    -warning 3009, suppressed with -suppress 3009, or suppressed
    with +nowarnTSCALE.
    [DOC: QuestaSim User's Manual - Verilog Simulation Chapter]
