13 years agoYou can always try typing
verror 3009 to see if there is more information about the error you are getting. In this case, it produces $ verror 3009 vsim Message# 3009: A module without a `timescale directive in effect, and without explicit timeunit and timeprecision declarations, uses the simulator resolution limit for both its time unit and time precision. This may result in incorrect delays and unintentional behavior in the module. Beware of simulator performance impact, and consider using the vlog -timescale or vopt -timescale options as a workaround. This message can be downgraded to a warning with -warning 3009, suppressed with -suppress 3009, or suppressed with +nowarnTSCALE. [DOC: QuestaSim User's Manual - Verilog Simulation Chapter]
