8 years agoModelsim error 3584 during RTL simulation
I'm attempting to perform an RTL simulation using Nativelink in Quartus Prime 15.1. My target device is an Intel EP4CE30F2917N (Cyclone IV) There's a parameterized I/O pad in my RTL which seems to cause ModelSim to post error 3584. See the transaction log below. I can't post the code, but given the info below, is there something I can do to resolve this error, or for the short term, suppress it from Nativelink. The .do file seems to be generated on each invocation which precludes inserting the -suppress argument there. Can it be inserted in some Quartus configuration file? vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -L rtl_work -L work -voptargs="+acc" TestBench_2# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -L rtl_work -L work -voptargs=""+acc"" TestBench_2 # Start time: 12:51:40 on Apr 06,2018# Loading work.TestBench_2# Loading work.MAIN# Loading work.IO_BUFFER# Loading work.CORE# Loading work.RESET_GEN# Loading work.CLOCK_GEN_PLL# Loading cycloneive_ver.cycloneive_pll# Loading cycloneive_ver.cycloneive_m_cntr# Loading cycloneive_ver.cycloneive_n_cntr# Loading cycloneive_ver.cycloneive_scale_cntr# Loading work.QUICK_USB# Loading work.WIDE_STROBE# Loading work.REGISTERS_BUILDINFO# Loading work.BUILD_INFO# Loading work.REGISTER# Loading work.REGISTERS_SCRATCH# Loading work.REGISTERS_SCRIPTCONTROL# Loading work.REGISTERS_SUPPLYCONTROL# Loading work.REGISTERS_DUTCONTROL# Loading work.REGISTERS_PMICCONTROL# Loading work.REGISTERS_RFFEINTERFACE# Loading work.REGISTER_FIFO_WRITE# Loading altera_mf_ver.dcfifo# Loading altera_mf_ver.dcfifo_mixed_widths# Loading altera_mf_ver.ALTERA_DEVICE_FAMILIES# Loading altera_mf_ver.dcfifo_low_latency# Loading altera_mf_ver.ALTERA_MF_HINT_EVALUATION# Loading altera_mf_ver.dcfifo_dffpipe# Loading work.REGISTER_FIFO_READ# Loading work.REGISTERS_I2CCONTROL# Loading work.REGISTERS_SPMIINTERFACE# Loading work.REGISTERS_MDMCONTROL# Loading work.REGISTERS_PHS_CONTROL# Loading work.REGISTERS_MISC_CONTROL# Loading work.SCRIPT_ENGINE# Loading work.I2C_MASTER_2# Loading work.RFFE_WRAPPER# Loading work.CLOCK_SWITCH# Loading work.CLOCK_CROSS_STROBE# Loading work.CLOCK_CROSS_STROBE_2# Loading work.RFFE_MASTER_2# Loading work.RFFE_MUX# Loading work.GRFC_MUX# Loading cycloneive_ver.cycloneive_io_obuf# Loading cycloneive_ver.cycloneive_io_ibuf# Loading altera_mf_ver.dcfifo_async# Loading altera_mf_ver.dcfifo_fefifo# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[0]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[1]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[2]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[3]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[4]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.2 Replies
Try by loading the design in ModelSim manually instead of native-like for simulation OR Try simulating by removing the IO buffer module with native-like. The error may be because of how IO buffers are handled in the design. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - AMath1
I am also facing same error on parameterised iobuffer . Did anyone solve this issue.. any leads is appreciated...
