16 years agokeep in mind you should be able to reuse the NativeLink .do script as long as you don't add any new HDL files to your project. in this case you'll need to re-run Run RTL Simulation, or directly edit the .do file.
i find it useful to run Run RTL Simulation once to get a .do file, then edit it to my liking and configure NativeLink to use my edited script rather than regenerating each time. again the downside is that you'll need to add new HDL files to the .do yourself or have NativeLink make a new one for you.
