8 years agomodelsim clock network stuck StX (gate level sim)
Hi All, I'm hoping someone can help with an issue I've observed in modelsim (10.5b, quartus 17.0). Simply put the clock network correctly drives the network right up to the point where it ...
8 years agoWell, I did target the Cyclone V series as this is the Lite version of Quartus II 17.1 (Windows) that I'm using, ModelSim is the Intel starter version.
I did modify the testbench a little, nothing major.
// Test bench for shiftRegister.sv
// test_vector.txt (bb_b_b <in>_<en>)
timeunit 1ns/100ps;
module shiftRegister_tb;
// Glue for the instance
logic in;
logic clk;
logic en;
logic d_out;
// Internal, needed by testbench
integer tst_vec;
integer scan_file;
logic t;
always# 1 clk = ~clk;
initial begin
tst_vec = $fopen("test_vector.txt","r");
// just be clean and set an initial value.
clk = 1;
en = 0;
in = '0;
t = '0;
end
always @(posedge clk) begin
// Start looping the test vector to generate our input
if(!$feof(tst_vec)) begin
scan_file = $fscanf(tst_vec,"%b",t);
in = t;
en = t;
end
else // when done just go quiet...
begin
en = 0;
in = '0;
$finish;
$fclose(tst_vec);
end
end
shiftReg dut (
.in(in),
.clk(clk),
.en(en),
.d_out(d_out)
endmodule
I had to change the name of the DUT as I didn't want it to overwrite the RTL simulation database. I've uploaded the netlist also. Have a look at it. The shiftReg.v file is the gate netlist. The other two are the design and TB files.
