14 years ago --- Quote Start --- That's what I thought should happen. The initialisation script seems to be trying to copy modelsim.ini to itself which obviously wouldn't work unless you were the owner. Copying /altera/11.0/modelsim_ase/linux/../modelsim.ini to /altera/11.0/modelsim_ase I cant' find where/why that write is happening. If the user owns the original then it writes a local copy no problem. --- Quote End --- That sounds bizarre. I have 11.1sp1 installed on Centos 6.2, and a few other versions under Ubuntu. Write a short Tcl script for Modelsim that triggers this error, and I can see if I reproduce the error. Cheers, Dave
