13 years ago
ModelSim and filename length limit
I'm currently trying to simulate the Hard memory controller example, and the files in "vhdl/submodules" are very long. For some reason modelsim fails to read any of the files with filenames greater than 83 characters !?? I'm running Quartus/modelsim under Windows XP 64 bit, a work colleague has Windows 7 64 bit, and modelsim has no problems reading the same files !
Any help would be much appreciated
Lee
    --- Quote Start ---
    put your project into a subfolder directly over a HDD for example D:\ms\
    --- Quote End ---
    Hi, just tried that, still the same.
    Lee
    Transcript is :-
    # -- Loading package STANDARD
    # -- Loading package TEXTIO
    # -- Loading package std_logic_1164
    # -- Compiling entity ddr_uniphy_hc_example_sim_e0_if0_id_router
    # -- Compiling architecture RTL of ddr_uniphy_hc_example_sim_e0_if0_id_router
    # Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov 2 2012
    # -- Compiling entity ddr_uniphy_hc_example_sim_e0_if0_addr_router
    # -- Compiling architecture RTL of ddr_uniphy_hc_example_sim_e0_if0_addr_router
    # ** Error: (vcom-7) Failed to open design unit file "./..//submodules/ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator_avalon_universal_slave_0_agent_rdata_fifo.vho" in read mode.
    # No such file or directory. (errno = ENOENT)
    # ** Error: C:/altera/13.0/modelsim_ase/win32aloem/vcom failed.
    # Error in macro ./run.do line 11
    # C:/altera/13.0/modelsim_ase/win32aloem/vcom failed.
    # while executing
    # "vcom "$QSYS_SIMDIR/submodules/ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator_avalon_universal_slave_0_agent_rdata_fifo.vho" "
    # ("eval" body line 42)
    # invoked from within
    # "com"
    # "if {[file exists msim_setup.tcl]} {
    # source msim_setup.tcl
    # dev_com
    # com
    # # the "elab_debug" macro avoids optimizations which preserves signals so tha..."
    If I shorten "ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator _avalon_universal_slave_0_agent_rdata_fifo.vho" to "ddr_uniphy_hc_example_sim_e0_if0_c0_csr_translator _avalon_universal_slave_0_agent_r.vho" (83 characters) it finds it !
    Windows XP has a limit on the total pathname length of 250 chars, not on the filename length. The pathname includes the starting "C:\" and null and the end of the path.
    --- Quote Start ---
    --- Quote End ---
    Thanks to both you (dave_59) and Taz1984, I forgot to rename the vho file back to its original name, after doing this all files are now found if I move the sim project to say c:\ms\ to minimise total pathname length :-)
    Many Thanks
    Lee
    Thanks, made interesting reading, same problem I had, I also can't believe the filenames have to be so long either !
    Yep, not only did they leave their brains at home on the day that they created those long filenames but there was an astonishing lack of testing.
