Altera_ForumHonored Contributor13 years agoModelSim and filename length limit Hi, I'm currently trying to simulate the Hard memory controller example, and the files in "vhdl/submodules" are very long. For some reason modelsim fails to read any of the files with filenames...Show More
Altera_ForumHonored Contributor13 years agoput your project into a subfolder directly over a HDD for example D:\ms
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
