17 years agoI didn't exactly understand what's the timing problem releated to memory operation. But if the data is stable a the clock edge, I meant you can simply add a register in your simulation, clocked from the said clock.
The user manual tells about an option to sample signals at a clock edge, but I'm not sure if it applies only to the list window or also to the waveform window.
