13 years ago --- Quote Start --- It turns out I had to add the adder_output signal to the process list. All of the Xs also disappeared. Pretty weird for it to do that. --- Quote End --- Not that wierd. You check the adder_output signal in that process, hence why you need it in the sensitivity list.
