12 years agoModelsim Altera Edition 10.1e - License not working
I have a Modeslim AE License that i try to present to Modelsim but unfortunately, if I start Modelsim AE it shows the infamous message Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE) is set correctly and then run 'lmutil lmdiag' to diagnose the problem. Unable to checkout a license. Vsim is closing. ** Fatal: Invalid license environment. Application closing. So I did the lmutil lmdiag thing and attached the outcome to this thread. In my opinion, the problem is not that Modelsim does not find the license file as its contents are read by lmutil. So the environment variable is set correctly, right? What else could be the problem? Is there no modelsim AE license contained in my license file? Since I'm not aware of all Altera vendor IDs, I don't know, if Modelsim is even in there. I also checked tips from other posts in this forum (like deleting the .quartus and .modelsim files in my home directory which did nothing but discarding all my custom quartus settings . . . ). I use the Altera tools on Debian Linux. The Quartus II (float) license is read correctly into Quartus during start from our licesnse server. But the Modelsim license is on my local machine. Regards, Maik
