--- Quote Start ---
... no unfortunately not, but I am following this discussion too. I will do the same for ubuntu then, once having more time.
--- Quote End ---
@fpgaengineerfrankfurt:
I hope the method remains same for Ubuntu as well. The trick worked for CentOS. In any case, the underlying principle (that I was missing) is this: specify complete path to the ModelSim executable in the launcher (or just the vsim command if the path has been included in the environment variables); and finally enable 'run in terminal' or 'application in terminal' option.
Kumar Vijay Mishra.
