14 years ago
Modelsim: add precompiled library
Hi all,
in my project, I need to include a library, MF_pllpack.all:
library ieee;
use ieee.std_logic_1164.all;
use std.textio.all;
use work.mf_pllpack.all;
I have compiled that library elsewhere in another folder.
How can I carry that compiled library under "Work" to use it in my project?
Thanks to all
    it's easiest just to compile it for the local work libarary.
    vcom the_directory_of_the_MF_pllpack/MF_pllpack.vhd
    otherwise you have to import it as an external (not work) library
    i have not got the .vhd file (MF_pllpack.vhd), but only the compiling folder containing the compilation files
    in that case either:
    copy the compiled files to the local work folder and try a refresh
    use the ML_pllpack folder as the work folder.
    map an external library to the MF_pllpack work folder:
    vmap MF_Lib MF_directory/work
    and then in your source:
    library MF_Lib;
    use MF_Lib.MF_pllpack.all;
    use the ml_pllpack folder as the work folder.???
    I have to include even other libraries...I have to mantain 'WORK' as work folder
    then I suggest you do not include MF_pllpack in the work library but map to it as another library.
    vmap MF_lib directory_of_MF/work/
    then in the code, instead of
    use work.MF_pllpack.all;
    write:
    library MF_Lib;
