11 years ago
Modelsim 10.3d tab size?
I want to change the tab size but I can't find the setting. Google search yielded a couple of options: thru preferences or edit modelsim.ini but they don't seem to work in this version. Any info is appreciated.
    --- Quote Start ---
    Tools->Edit Preferences->ByName->Source->Tabs
    --- Quote End ---
    Awesome!. Interesting how the "Find" button doesn't find it unless I "Expand all" first. Thanks.
    --- Quote Start ---
    Mind elaborate the tab size that you are referring here?
    --- Quote End ---
    Sorry. When editing Verilog code and I press tab to indent the code. I think it may be set to 8. I'd like 4 or so.
    Hi Rodo,
    I believe you can try to ask Altera about if there is any way to customize on this. But I believe you should anticipate that the priority might be low since it is a not a bug or error.
    --- Quote Start ---
    --- Quote End ---
    Thanks lot for the sharing.
    Nice to learn that we can change the tab size. I have been using space to workaround which is tedious.
