11 years agoModelsim 10.3d tab size?
Hi, I want to change the tab size but I can't find the setting. Google search yielded a couple of options: thru preferences or edit modelsim.ini but they don't seem to work in this version. Any...
11 years agoHi Rodo,
I believe you can try to ask Altera about if there is any way to customize on this. But I believe you should anticipate that the priority might be low since it is a not a bug or error.
