13 years agoI have several versions of Modelsim installed on the same machine, however, you need to be careful about your environment setup.
Type 'where' at the Modelsim prompt and post the output. Type 'parray env', and then copy-and-paste its output. Edit it to remove most of your personal setup, but keep any variables involving MODELSIM and MGC (Mentor Graphics Corp). I'll see if I can spot the problem. Does your project folder have a modelsim.ini or .mpc file? Cheers, Dave
