18 years agoAnother problem occurs :(
use configuration work.con can make modelsim select the correct configuration, but when I return back to SOPC Builder and try to re-generate system, the following error reported: Error: freqmeasure_wholesystem_inst: Error (10481): VHDL Use Clause error at FREQMeasure_WholeSystem.vhd(149): design library "work" does not contain primary unit "con" File: E:/Altera_Project/My_IP/FreqMeasure/FREQMeasure_WholeSystem.vhd Line: 149
