18 years agoI am using Entity-Architecture Pair Configuration instead of Lower-Level Configuration, so that I can decribe two architectures for the same entity in a single VHDL file, and then use Entity-Architecture Pair Configuration to configurate the entity in the upper-level VHDL file.
Do you know with Entity-Architecture Pair Configuration, how to make modelsim understand the configuration?configuration con of FREQMeasure_SingleChannel is
for rtl
for U1: FREQMeasure_PeriodCounterDuringStrobe USE ENTITY WORK.FREQMeasure_PeriodCounterDuringStrobe(WithStrobeOutput);
end for;
for U2: FREQMeasure_PeriodCounterDuringStrobe USE ENTITY WORK.FREQMeasure_PeriodCounterDuringStrobe(WithoutStrobeOutput);
end for;
end for;
end con; Thanks for your patience...
