12 years agoModelsim - specifying path to .hex file
We have some RAMs with .hex initialisation files. In the megawizard we just specify the name of the file with no path and then in quartus we simply add a search path in the .qsf to point to the directory containing the .hex files. Everything works fine and we can keep the .hex in a central, common location.
The problem, or more like an inconvenience, arises in modelsim in that we have to copy the .hex files over to the working directory (or create a symbolic link) to make them visible to modelsim. Is anybody aware of a method of a more eloquent method rather than having to copy them over. Is there something similar in modelsim to the quartus search path? Thanks.
