14 years agoThank you for your reply , fpgabuilder.
I have solved the path issue. Seems like there can't be any "space character" in the file data path. I thought that I am compiling the file on the "C:/SDRAM_controller_ModelSim_test/" folder , but I compiled the wrong path "C:\Documents and Settings\Yuyex\Desktop\modelsim test1" :eek: (i compiled my backup files .. omG) Here comes another issue from ddr_par.v which is still confusing me. Error message : 1. (vlog-2155) global declarations are illegal in verilog 2001 syntax. 2. undefined variable: length_1.3. 'length_1' already declared in this scope (work).
code (ddr_par.v):
// burst length
parameter length_1 = 3'b000;
parameter length_2 = 3'b001;
parameter length_4 = 3'b010;
parameter length_8 = 3'b011; .... (so on)I cant use 'define since I still need some selection function on the parameter (at ddr_par.v), such as :
parameter num_clk_read = (mr_burst_length == length_1) ? 1 :
(mr_burst_length == length_2) ? 2 :
(mr_burst_length == length_4) ? 4 :
(mr_burst_length == length_8) ? 8 :
1; // default From your last reply, --- Quote Start --- a. How are you using the parameters? Are you using the parameters in the same module as you have the `include statement? Or are you using those parameters in blocks lower in the hierarchy? --- Quote End --- I am using ddr_par.v in all of the other .v files , that's why I have to use 'include in order to reduce the lines number. --- Quote Start --- 2.b. Also, something to look for is if you are using parameters as variables e.g. assign Length_1 = 3'd4; --- Quote End --- I'm using bit expression for this Length _1 since this bits will be sent to "SDRAM Load Mode Register" to initialize the characteristic of SDRAM itself. Do you mean that it's better to use assign than parameter? --- Quote Start --- 2.c. Maybe your problem is not from the parameter declaration but the `define declaration after the code is successfully compiled. What if you enclose the argument to the defined term as (cs_clkcnt == NUM_CLK_tRP) --- Quote End --- This "global parameter" thing is the problem for now :(( Thank you in advance, Yuyex:o
