User1582192733150209
6 years agoModelsim –intel 10.5c reported a Fatal Error when I was simulating Intel FFT ip core
Hello Sir/Madam, Basic Information Quartus prime pro 17.1 + Modelsim-Intel Starter edition 10.5c +Arria10gx I generated an Intel FFT ip core, because option to generate a design example is in grey...
pbandjam
3 years agoHello,
Did you ever find a solution to this problem? I am running into the same error.
Here is a description of the problem:
- The simulation runs initially but stops with a fatal error once the FFT begins sourcing samples
# ** Fatal: (vsim-3421) Value -1 is out of range 0 to 4.
# Time: 21980 ps Iteration: 1 Process: /ifft_tb/u0/auk_dspip_r22sdf_top_inst/r22sdf_core_inst/gen_natural_order_core/gen_stages(0)/r22_stage/gen_bfi/processing_bfi_cnt_p File: ./ifft_ip/simulation/submodules/mentor/auk_dspip_r22sdf_stage.vhd Line: 789
# Fatal error in Process processing_bfi_cnt_p at ./ifft_ip/simulation/submodules/mentor/auk_dspip_r22sdf_stage.vhd line 789 - From the beginning of the simulation, I get many warnings like this
Warning: NUMERIC_STD."=": metavalue detected, returning FALSE
# Time: 2500 ps Iteration: 1 Instance: /ifft_tb/u0/auk_dspip_r22sdf_top_inst/r22sdf_core_inst/gen_natural_order_core/gen_stages(0)/r22_stage/gen_bfii/bfii_inst/bf_control_inst
I see in the waveform viewer that several signals in gen_natural_order_core/gen_stages(0)/r22_stage have undefined values: bfi_out_real, bfi_out_img, and twidaddr_s
So perhaps there's something wrong in generating the correct twiddle address? Or with generating the natural bit order?
I've generated theFFT IP core with the following parameters:
- Variable streaming
- Length = 128
- Natural Input Order
- Natural Output Order
- Direction = Bidirectional
- Fixed Point representation
- Data Input Width = 16 bits
- Twiddle Width = 32 bits
- Data Output Width = 16 bits
I am using:
- ModelSim Starter Edition 2020.1
- Quartus Prime Version 20.1.1 Build 720 11/11/2020 SJ Lite Edition
After generating the HDL, I created a TCL file "mentor.do" based on the template "msim_setup.tcl" (both attached).
I am running a simple testbench "ifft_tb.sv" (attached).
Thanks for any insight!
PBJ
