User1582192733150209
6 years agoModelsim –intel 10.5c reported a Fatal Error when I was simulating Intel FFT ip core
Hello Sir/Madam, Basic Information Quartus prime pro 17.1 + Modelsim-Intel Starter edition 10.5c +Arria10gx I generated an Intel FFT ip core, because option to generate a design example is in grey...
SyafieqS
6 years agoHi Jim,
My first debug step would be, go to auk_dspip_r22sdf_stage.vhd line 803, figure out which variable is implicated and adjust its declaration range. This may fix the problem or cause another. But it might give you a clue.
