11 years agomodel sim 11.1 wont install, cannot find quartus installation ??
I am running an Acer computer with Winoze (aka Windows) 7.
I have a couple of cheap Cyclone II boards so installed Quartus II 10.1 a while back. I had successfully installed ModelSim-starter 10.1, and used, along side. I had no success installing the 10.1 University Program (UP) material and getting either of Qsim or its waveform editor running. There was an error raised during the install, and while I had menu items or desktop shortcuts they were blank (no glyph) and reported no binary attached when you double clicked on them. I found downloading the 11.1 version of the UP gave me Qsim (??) but not the waveform editor (double ??). I decided to remove 10.1 install Quartus II 11.1 sp2 build 259. All good expect now when I go to intall ModelSim-starter won't install. It doesn't "find" an installation of Quartus II 11.1 sp2 , and even when I point it to the installation directory manually it refuses to acknowledge the existing installation. I have tried c:\altera\, C:\altera\11.1sp2, C:\altera\11.1sp2\quartus, C:\altera\11.1sp2\quartus\bin etc. Quartus II 11.1 sp2 is happily running so the install should have happily touched up the registry et cetera so the ModelSim installer should have found it there - if it checks the registry. Has anyone seen this before? Better still has anyone fixed this problem before? Reacap, 10.1 Quartus II and ModelSim were uninstalled before the 11.1 install of both tools. I am likely not interested in chasing done the failed UP install as I am happy (I guess) to use ModelSim instead of Qsim. Cheers, A
