annamalairaj
10 months agoMinimum pulse width violation on EMIF-HPS
We are observing Minimum pulse width summary violation on three clocks in EMIF. Snapshots of Minimum pulse width violation on each of these clocks are attached. Quartus version: 25.1.1 targeted F...
annamalairaj
3 months agoI have used Superior Performance with Maximum Placement Effort performance option and also tried the EMIF document optimize timing method by updating the Placement Effort Multiplier to 2 still same violation is observed.
I have also attached the HPS subsystem files.
- AdzimZM_Altera3 months ago
hi annamalairaj
I make hps_subsys as a top level, set the hps bridge as virtual pin and compile the design.
I don't get the timing violation as you see.
Can you try that from your end?
