15 years agoFile an SR. Usually it's the clock tree that's the problem, but you're right that it's spec'd a lot higher.
That being said, it would probably make sense to architect as a DDR interface and feed it with a 211.5MHz clock. Naturally that would remove the problem. I'm sure you're bringing it down to that rate or slower anyway.
