Migration Error: Unable to Open data_pattern_generator Service in Quartus Prime Standard Edition
- 3 years ago
Normally IP migration or device migration, from diff version or edition, sometime there will be an issue.
If the gap of the prior tool is big, better things to do is to instantiate directly the IP from catalog and compile.
Also, need to check as well the IP version, big gap might have issue (of course due to IP will keep updating for improvement and might be not fit with your design).
I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
