Migration Error: Unable to Open data_pattern_generator Service in Quartus Prime Standard Edition
- 3 years ago
Normally IP migration or device migration, from diff version or edition, sometime there will be an issue.
If the gap of the prior tool is big, better things to do is to instantiate directly the IP from catalog and compile.
Also, need to check as well the IP version, big gap might have issue (of course due to IP will keep updating for improvement and might be not fit with your design).
Sorry for late response,
Thank you for your advise, so I'll try to migrate the IP version again.
