zjj
5 months agomemory infer
in my project that base agilex7 fpga, I need to use bit mask memory. the bit mask memory rtl behavior as follow. as quartus only support byte mask memory, so I think quartus tool should use logic(...
FvM
5 months agoHi,
the code is describing read-modify-write action that can be basically implemented with M20K block ram. Due to synchronous operation ram_addra is evaluated in different cycles for read and write, shown simple behavioral code is possibly not working as expected.
Question is if you require write to different address every clock cycle, in this case pipelined implementation with Agilex quad port mode can achieve the required functionality. But I doubt that it can be simply inferred.
Regards Frank
zjj
4 months agoso I am worry that logic function of the fitter netlist is inconsistent with rtl code behavior. how to verify it ? is there tool to verify the logic equivalence between netlist and rtl code?
