15 years agoYou left the wren open on your RAM-block, and it seems that is taken as a '1'. This overwrites the data at address '00h' immediately with '00h', and the expected '30h' will only be there for one single clock. Instead of using signaltap you could have simulated your design, and you would have noticed the 30h to 00h transition in your LCD data directly after startup.
