15 years ago --- Quote Start --- Did you use a MIF to initialize the RAM? Or do you write a stream of data into the RAM by logic? In the first case inspect the MIF. In the second case it will be in the logic. Can you post/copy the code? --- Quote End --- i used a MIF file, checked it just to make sure it has my desired data for several times, all other addresses other than 0 sends data that matches the MIF
