MegaWizard Plug in Manager GUI ipdate for Windows 11
Hi OP,
Unfortunately, this issue will not be fixed. When I mentioned that the Lite/Standard editions are in maintenance mode, it means no new features will be added in the future.
Only fixes for issues that block the design process—such as internal or fatal errors—will be provided (if no workaround is available).
For example, if you encounter a fatal or internal error during compilation, you can search the Knowledge Database (KDB) for similar issues. If no workaround is available, we will escalate the issue to the tool specialists for further investigation and provide a workaround or fix.
However, if a workaround exists to resolve the issue, no fix will be provided. (In Quartus Pro, such issues are fixed regardless of workaround availability.)
In your case, the issue does not block or hinder your design process and can be resolved by manually resizing the window. Since a workaround is available and the issue is not critical, no fix will be provided.
I understand your disappointment and appreciate your feedback on improving the tool’s usability and professional appearance.
Due to resource constraints, our focus is primarily on the Quartus Pro edition. If you have any feedback regarding Quartus Pro, please feel free to reach out to us—we would be glad to look into it.
Richard
