12 years ago
MegaWizard - Altera PLL 13.0 - generation error
HI
I am trying generate Altera PLL 13.1 Megafunction
(when trying either 64 bit Quartus Version 13.1 - Windows XP Professional 64 bit Service pack 2
or 32 bit Quartus version 13.1 - - Windows XP professional - Service pack 3)
The generation gets as far as
>info : Generating simgen model
>Error: Execution of script C:...../Temp/alt6029_789481781428619152.dir/0002_pll_replace_gen/proj.tcl failed
>Error:Error starting the process ([and,Settings/flong/Local, Settings/Temp/alt6029_789481781428619152.dir/0002_pll_replace_gen, C:/altera/13/1/bin//quartus_sh -t, run_simgen_cmd.tcl]). Cannot run program "and" (in the directory "C:\Documents"): CreateProcess error=2, the system cannot find the file specified
Can anyone shed any light on this error for me please.
Fionbarra
    --- Quote Start ---
    Thank u, my problem is solved!!!
    --- Quote End ---
    I have the same issue.
    What I should change in environment variables?
    My TMP path is %USERPROFILE%\AppData\Local\Temp
    Vraifl
    I got the same Problem, with Version 14.0 as mentioned in the Thread http://www.alteraforum.com/forum/showthread.php?t=46673
    I tried to fix this with changing the environment variables without success.
    When I enable Compatibilty Mode for Win 7 i got:
    [14736 Error: Wizard "Altere PLL v14.0" cannot be launched]
    and a Error Log File :
    [A Fatal error has been detected by the Java Runtime Environment ...]
    When running in normal Mode on my Win 8.1 machine i got no error log or massage, thats what i mentioned in the other Thread.
    I deinstalled the Altera Software and alle Java Applications (Java + SDK) and start a new try with the latest Release but there was no improvement. I changed the jre64 installation with the actual java runtime but that also doesnt work.
    I hope that someone got a solution for this Bug!
    I have the same problem when generating Altera PLL 13.1. I tried changing environmental variables of TMP to some other paths that don't have spaces in names, but nothing changed. It's interesting fact that I can build other IPs from Megawizard (for example NCO), but PLL is simply not building right. Is there any new advice I could follow? Please help :)
    Matija
    --- Quote Start ---
    Matija
    --- Quote End ---
    Hi
    I gave up to use this PLLs
