11 years agoMen you rock.... "problem was this i fixed it","where to fix it?","in the environment variables","thank u, my problem solved!!!" - WHAT THE HELL SHOULD I WRITE INTO THE VARIABLES EDIT WINDOW?????????????? if somebody cares,please post :)))
i got that It was set to "C:\Documents and Settings\...\Temp which as you can see has spaces in the directory name." so what now? should i delete all the spaces?
