12 years ago --- Quote Start --- Thanks guys. It was not the project name or path as much as the environmental setting for the path to TMP that was my problem. The path to TMP was C:\Documents and Settings\etc..\Local Settings\Temp This PATH must be called by the program run to generate the simgen model. Regards Fionbarra --- Quote End --- Hi Fionbarra, I have ran into the same issue with Quartus 13.1 when I generate the Qsys. How do you resolve the problem? Thanks, Frank
