12 years ago --- Quote Start --- Some Megawizard functions are written in - dunno - C or C++, others in Java. The latter ones sometimes are sensitive to spaces in the path. Try it, you won't be disapponted. Off-topic: today I tried to build a MinGW C application with an "_" in its project name. Wouldn't compile. Tried without the "_" in the name, no problem. Sigh... Best regards, Ben --- Quote End --- Thanks guys. It was not the project name or path as much as the environmental setting for the path to TMP that was my problem. The path to TMP was C:\Documents and Settings\etc..\Local Settings\Temp This PATH must be called by the program run to generate the simgen model. Regards Fionbarra
