14 years agoI am really confused. CT6464A667 should have the same timing parameter as CT12864AC667, why doesn't CT12864AC667 work, but CT6464AC667 works.
--- Quote Start --- hi everybody, I am using example driver generated by mega wizard and altera ddr2 controller(with phy, No-AFI interface) as example to do a test. memory clock speed is 200MHz. I met with a very strange issue: the generated SOF can't work with Crucial DDR2 SODIMM, CT12864AC667, which is 64 bit width , 1G bytes capacity , with the help of signaltap, i found that PHY never return read data valid to controller read request. But it can works well other two Crucial SODIMM, CT6464AC667(512M bytes capacity) , CT12864AC800(1G bytes). I checked timing parameter , looks like all parameter in the range of JEDEC requirement . Could anyone give me some hints? thanks alot xyzxyk --- Quote End ---
