9 years ago
Maximum width of FIFO
The maximum width of a FIFO in the IP catalog GUI wizard is limited to 256 bits.
I need a wider FIFO and want to avoid cascading FIFOs.
Will it work to manually change the generated HDL instantiation file to the width I desire (for example 1024 bits) ?
    Did you try it? what were the results?
    Why not use two parrallel fifos?
    --- Quote Start ---
    --- Quote End ---
    No it isn't. IP user guides say
    --- Quote Start ---
    Note that you can manually enter a number that is not in the drop-down list.
    --- Quote End ---
